Is there such a thing? or any device to extend the wifi range? Like a car kit with antenna which increases the wifi range instead of phone reception?
n80 wifi antenna?
maybe an amplifier would help
Youi could probably use a wireless extender or a router like the linksys wrt54g set up in a repeater mode (or a dedicated unit), but somehow i don't think that you can get an antenna plugged in unless you start heavely modifying your n80
René
is the same internal antenna used for voice calls and wifi usage? if so maybe an external antenna can be connected to the phone using the pop port.
tysons_2001 wrote:is the same internal antenna used for voice calls and wifi usage?
No.
