Since I am using the E70, and it is missing a stopwatch:
In case anyone is interested, I have made a Java stopwatch MIDlet
that may be useful to the occasional need on E70, and other devices
which miss a standard system stopwatch (both MIDP1.0 and MIDP2.0
versions available).
It supports up to 5 simultaneous stopwatches, each with 40 split/lap
times including persistent saving. It is nothing fancy graphic wise,
but may be useful for the occasional need.
It is of course for free, please see:
http://www.tevero.no/espace/stopwatch
For the Nokia Exx series, you should select the MIDP2.0 version.
Kolibri wrote:Since I am using the E70, and it is missing a stopwatch:In case anyone is interested, I have made a Java stopwatch MIDlet
Thanks for sharing with app with us and having made available for free. I've tried it on my E61 and it works a treat. The UI, although not mind blowing, is clear and simple and i like the fact that you've included a small user guide whithin the app itself.
Hi Kolibri,
Thanks for the nice app! Very useful a stopwatch on my E61!
Thanks!
Wouter
Hi Kolibri,
Thanks!
Wouter
