hi great forum but i haven't found an naswer to my problem i just bought my new Nokia N70(previously had 6630) and i start a program and exit with the red key and when i hold the menu key it shows me that there are no programs runing and if some program is runing i can't close it :con? thx in advance
Nokia n70 problem
The N70 exits the app if you hit the red key, it's the same like exit. If you want to keep the app in background, hit menu key twice. Not all the apps can be closed when menu key is pressed, usually the ones which are asking for confirmation cannot be closed in this way.
10x and boy that sure sux 😞
Well it just needs to take a while to get used to it. Menu twice - one red... it's not such a big difference.
N70 and all new S60 phones work that way. Is a question of "taste", nothing more.
and how long does your battery last ? because my one day and then i have to charge it ... 😡
Mine needs recharge after around two days, depending what I'm doing with the phone. Normally I listen 2-3 hours of music, around 1 hour of games and 10...30 minutes on talk. I am curious to see how long is the standby period, but I can't let the phone down🙄
With 3G and Bluetooth on, one day, off 3-4 days!
then there must be something wrong with my battery 😡 :frown:
