Hi i was just wondering if someone could tell me how i copy my messages from my phone 2 the memory card? the first time i changed the 'memory in use' option from phone to card, it asked me if id like 2 do it, but i said no. and since then, i havnt had the option 2 do it, is there any other way? thanks.
N70 - messeges 2 memory card
It's pretty easy. Select MMC for storing the msgs, go to C:\System\Mail and copy the whole dir to E:\tmp (or any other directory, excepting System). Select phone memory for msgs and from E:\tmp or where you put it first copy the Mail dir to E:\Sytem. When asking for overwrite, choose "Yes". Select the MMC for msgs again and you've done it.
Make first a backup for the case you do something wrong, so you won't loose your msgs.
just saw this, thanks.
