hello everyone,
i occationally get the out of memory error when i use the browser a lot. i have to turn off the device and turn it back on to get around this. also i occationally get a connection time out error while browsing the internet with the built in browser through t-zone.
also another one is the battery bug, where the phone does not have the low voltage cut-off. it will run the battery down so low that charging through the phone is not possible anymore. you would have to get an external charger to recharge the battery.
so does the new firmware 2.0618.06.05 fix the above problems ?
thanks
Tam
