Browser Shortcuts gone in new firmware (E61)
3 replies · 5,009 views · Started 07 September 2006
I just upgraded to the 2.x firmware, and to my horror, found that the shortcuts for Bookmarks (1), Search (2), Zoom in (*) and Zoom Out (#) in the browser are all GONE !
I can't find a setting to re-enable them.
Can anyone please check this on their upgraded E61 and report back.
If true, that will be a major feed-back to Nokia 😡
UpdateIf I Press and Hold (!) the Blue Arrow key, I can activate the shortcuts - and use Calcium etc. Pressing and releasing Blue Arrow - like when you want to enter a letter in a SMS does NOT work for shortcuts or Calcium.
Regards
Michael
How did you upgrade to the new firmware?......I thought it wasn't available for the E61 yet.
Cheers
Ventmore
I used local Nokia Service Center in Copenhagen, Denmark
I just found, that Calcium won't accept any numbers anymore after upgrading. Pressing a number key produces a 'beep' but no number on the screen..
Regards
Michael
bodstrup wrote:I used local Nokia Service Center in Copenhagen, Denmark
Regards
Michael
Both issues are related. With the new firmware, you now have to hold down the blue shortcut key when trying to access the * and # symbols to zoom in and out while browsing the web.
Likewise, Calcium will work if you enter the numbers with the use of the blue shortcut key - it's something the Calcium developers will have to address.
EDIT: Oops, my bad, I didn't see the updated first post.
