Is There Any Way To Upgrade Firmware By Myself?
13 replies · 2,077 views · Started 05 December 2002
Maybe By Infrared Or BlueTooth Is There Any Programs Out There?
No there is no way you can do it with BT or IR.
You need to buy a special device for it.
Try searching for posts from Fox Hound,
or PM him and you will get all info about that it think.
He has one of those i suspect.
It's Nokia's Flash Box, it can upgrade and downgrade and even change languages. In just a flash... 😊
[quote="😊"]It's Nokia's Flash Box, it can upgrade and downgrade and even change languages. In just a flash... 😊[/quote]
stop with the changing languages stuff still no arabic 😞 😞 😞
not just all of these
but you can also make ur phone shows "Contact Retailer"
so backup the original files first
http://gsm-technology.com/index/USA,en,USD,details,id_gr,81,id_pr,592.html
thanks to aespina for the link
So is there any device or flasher that will let me fix the "contact retailer.." bullshit screen I got ?
I think all hardcore 7650 users need it.
[quote="PURPLEMUSTANG"]So is there any device or flasher that will let me fix the "contact retailer.." bullshit screen I got ?
I think all hardcore 7650 users need it.[/quote]
yes the all flasher can fix that "COntact retailer"
if u hav the flasher just find the original file then flash it into ur phone and ur phone will be fixed
[quote="FOX HOUND"][quote="😊"]It's Nokia's Flash Box, it can upgrade and downgrade and even change languages. In just a flash... 😊[/quote]
stop with the changing languages stuff still no arabic 😞 😞 😞[/quote]
I read in another site that it does change to arabic! :-?
Pretty sure it says so, but still even though, nobody tried it
