How to check
1 replies · 1,235 views · Started 09 September 2006
Hey I am new to Symbian
I want to Know how to check
1) OS version and firmware versions
2) Lifetime Versions
3) Other Datails like Flash and Repaired times
could you use this code : *#92702689# like other nokias
Assuming you have a 3230 as you posted in the 3230 forum, then the answer to your first question is: Symbian OS 7.0s with S60 2nd Edition Feature Pack 1 (S60 2.1), and the firmware revision you get with *#0000# on the standby screen (where you would dial a number to make a call).
