PC Connect problem
1 replies · 1,453 views · Started 10 September 2006
Hi.
Is there any other program- beside PC Connect - that allow you to transfer data between Sendo X and PC. I'm asking because PC Connect is just hanging when I try to start it and reinstalling doesn't help.
Thanks for any clues.
PS: I would rather not format my PC hard drive :P
Try using a card reader to store the files on the memcard and then use FExplorer to put them in the correct folder in your X.
