firmware problem
4 replies · 1,965 views · Started 10 September 2006
i have a n80 on o2 and also have navicore personal 2006 to put on it-the problem is 02 dont support the version of firmware i need to use this with my phone and nokia have advised me that there is no way around this other than to wait for the network to release the version i need,im now selling this phone so my question is-if i spend a bit more on a sim free n80 will this free me from network restricted firmware? will i be able to go to a nokia service center and get the latest 5. something something as opose to 3.something and 4.something? my problem is not with the sim card its the firmware!! thanks!
I have an o2 N80 which I flashed myself with the latest v4 firmware.
You loose the o2 things like the start up screen and theme.
You also loose the o2 settings for wap and mms ect but these can be easily installed using the settings wizard.
If you asked more firmly maybe the service centre will upgrade to generic v4 firmware?
A phone with generic firmware, lost all operator related restrictions. You can use that kind of phone with any operator SIM.
nj7 wrote:A phone with generic firmware, lost all operator related restrictions. You can use that kind of phone with any operator SIM.
Even if you flash it with generic firmware, it doesnt mean its unlocked....
flashing with generic firmware will not remove locks, just remove operator specific settings.
But I would like to say that I have had several o2 phones and so far none of them have been locked to o2
