problem with dev cert and permissions
5 replies · 0 views · Started 10 September 2006
i have a devcert with full capabilities. one of the APIs i use requires
SwEvent capability.
i checked and confirmed from www.symbiansigned.com that my devcert includes
that capability.
however, i am still getting errors in calling the API. the API is for
capturing hotkeys. i keep getting KErrPermissionDenied.
Hi
Its possible your process is trying to load a DLL which does not have the
capability of your process. If you really have ALL capabilities that is
likely - most Symbian DLLs have capability ALL-Tcb, so if your process has
Tcb, then it won't be able to load very much.
There is an easy way to find out.... follow the instructions in
FAQ-1344 How do I Enable Platform Security Diagnostics on the Symbian OS
Emulator?
http://www3.symbian.com/faq.nsf/AllByDate/138E15D7FA8E656D802570C0001BDB3B?OpenDocument
Regards
H
"droll" <[email protected]> wrote in message
news:[email protected]...
> SwEvent capability.
includes
> that capability.
i did try this. i disabled platform security on the emulator and my
application works fine.
so you reckon the problem is the DLL i'm trying to load?
so there's no way for me to use capturekey from RWindowGroup()? oh my...
"Hamish Willee" <[email protected]> wrote in message
> Hi
> Emulator?
> Regards
> H
> news:[email protected]...[color=green]
>> SwEvent capability.
> includes
>> that capability.
>[/color]
btw, i've read and modified my MMP file for CAPABILITY keyword. however, i
don't know where to get the vendorid. i've simply put it as 1 since setting
it to 0 means it is not required for security checks (which i assume means
my exe won't have any privileges).
help??
>> Hi
>> has
>> OS
>> Emulator?
>> Regards
>> H
>> news:[email protected]...[color=darkred]
>>> SwEvent capability.
>> includes
>>> that capability.
>>[/color]
>[/color]
Check the emulator output file (%temp%\epocwind.out) for any lines
containing "PlatSec" - this should tell you where there are capability
problems. Add the listed problem capabilities back into your MMP file
(don't use ALL - as Hamish says, it will fail to load many Symbian DLLs)
Mark
Symbian Developer Network
found the problem. my UID3 was in the wrong range.
"Mark Shackman" <-> wrote in message
> Mark
