Problem using Fotodock over orange GPRS...
2 replies · 1,498 views · Started 05 December 2002
have set up my fotodock account and now can't seem to connect - Orange GPRS (using standard settings) connects fine, then says connecting to fotodock, then get disconnected from server try again? message a few seconds later.... am using the setting for fotodock from the configuration page on their website...
anyone successfully connecting using orange? any suggestions?
thanks for any help...
I am not to familiar with Fotodock but I do have another program which sounds similar and I connect through Orange GPRS. The first thing is to try using an external GPRS connection:
Data Bearer:
GPRS
Access Point Name
orangeinternet
and leave all the other settings as normal or blank
if this doesnt work try (if the option is there) to switch the Ftp Passive mode on and see if that works...
P
