when I connect my E-61 to the computer using USB cable, the connection seems not stable. for example, if I copy a file to the phone, after the copy is completed, the connection will be lost and I have to unplug and then plug the cable to the phone. has anyone here got this problem? is there any way to solve this? thanks
E61- unstable cable connection
Maybe... Try uninstall, clean registry and install again PCSuite.
I experienced the same thing and an uninstall/reinstall of PC Suite fixed the problem.
Mark
