Helppp :(
6 replies · 1,781 views · Started 11 September 2006
My n80 was working perfectlyyy fineee until today 😞
when i open the gallery it opens but when i press to open images .. the screen just freezes there :con?
when i press the camera button the screen freezes in transition 🙄
even the menu and nearly most of the other functioning has become realllyyyyy slowwww :frown:
plz plz help me :frown: and i cant even goto a nokia centre cuz they dnt have n80's in canada nd neither is my warranty covered here :frown:
i think wat ur saying is restore factory settings did that
styll wnt work
the camera takes VERY long to open if at all once in 10 times it opens the app.
the gallery(images) does not open at all
web isnt opening either
calendar didnt open
music player gets stuck while playing music
sometimes dialling or redialling nos. is EXTREMELY slow
wats wrong wid my n80 ? :frown:
Are you using the standard memory card or is this a new one? Try it without the memory card in and see if that makes a difference.
If it doesn't then I think you're probably going to have to take a trip to a service centre.
jayk wrote:i think wat ur saying is restore factory settings did that
styll wnt work
calendar didnt open
Is not do a rest to factory settings, but do a phone soft format: *#7370#
i did the soft phone format 😊
and then it said culdnt install all apps. from memory card or something...
so i turned it off and turned it onn .... same shyt NO changes .. nothing worked(i mean stuff that wasnt working b4 dint work after it either)
then i removed the memory card .. AND the phone is working PERFECT nd at a nice speed ... :|
AND it is the original nokia memory card 128 mb the 1 nokia gives in the phone package :|
nehow thanks every1 😃 now can u tell me what to do with the mem card ? wats wrong wid it ?
im dancing rite now that my phone isnt malfunctioning 😃 😃 😃
PS: i forgot to note down my contact list ... lol
