~ I'v been using my 6680 phone for a while now.. n i was using a 1Gb mmc card..after a month i started having trouble with the memory card, it wouldnt open any folders, (it said "menu error -25"😉. I didnt really much bother about that n i stared using a 64Mb memory card ! ~ now i thought of scanning my phone n thats when i found out that the antivirus program was infected by a virus.. ! i switched off my phone n tried 2 restore the factory settings.. i took out the memory card n tried that.. but now when i insert my mem card it doesnt work ! all the applications get jammed n it simply doesnt work !!!~ iv tried the 64Mb mem card as well as the 1gB one ! What can i do ???? the phone works perfectly fine without any mem cards ~! helppppppp !!
Help !!!!!
i think ya have install some soft APP dat have crach ya MMC....
is better to reformate ya mmc by using mmc reader PC....
under FAT32...ok...
if ya need more explaination click here
No. No. No. At least, no to formatting the memory card with the FAT32 filesystem. The phone does *NOT* handle FAT32, but 16-bit FAT (VFAT); best to reformat in the phone (and might be a good idea to reformat the whole phone, too).
