Hi All,
Here's a sis app for sms delay facing on certain Nokia models. This app is applicable for N71,N73,N80,N91 and and N93.
Install this app to your phone. Please note that the handset may run slowly upon first installation of this application, this may last for a few
minutes before returning to normal; this will only happen upon first installation.
Hope this helps.
Cheers...😊 😊 😊
sms accelerator.zip (2 KB)
have you made this yourself? i would try it out but i don't know if it could be a virus or something 😊
Hi there,
No...I wish I'm that clever 😊
Got it from a 'reliable source' and as understand some N80 users is facing this sms delay issue.
Virus??? It's the same skepticism posts I received when I posted this app on other forums. I should have thought of the implication before doing this.
The advice is, if you're facing this issue, you may want this help to resolve it. If really a virus, format it then you can get me shot and banished me with a bad reputation :tongue:
Cheers 😊
I think I'll wait till it's added to the My-Symbian download archive before trying it :icon14:
i would try it to see if it did work but i formatted my phone for the 2nd time just saturday, ill keep this handy for when it goes slow again
Thanks infantry188, it works just fine. At last, i think my sms sending delay issue is finally resolved! :icon14:
A word of caution :icon4: to the others who are thinking of downloading this app... the app works well, so far, no doubt but there is a trojan horse 😮 that comes with the file :icon13: so beware, and always keep your protection on.
wt does this trojan horse do???
dear simmett, i didn't really give it a chance... killed it b4 finding out. But my sms problem's solved though... 😊
The software is now on the Nokia website http://www.europe.nokia.com/A4149167
Quote "This application accelerates the sending of SMS messaging. It is recommended to download this file, even if you have not experienced any problem with SMS sending."
Have installed it, works GREAT! .. i now have a question, so with this .sis, i take it as the problem will not return? IF it does return, do we re-install it?
It is also on the N80 Support page here: http://www.europe.nokia.com/A4149142
I love how they've called it the accelerator lol, like the old speed was normal or something!
