Application not visible after installation
4 replies · 3,306 views · Started 11 September 2006
:con?
I installed a trial version of the SlovoEd dictionary application on my N73. Installation seemed to work fine. However, after installation the application is not visible in the menu. The Application Manager tool reports installation of SlovoEd is OK. I installed both on internal and miniSD memory but that did not make any difference.
The webrequest form of Epocware did not work, so perhaps someone here knows what the issue is.
mr g wrote:Is it not in the 'applications' folder?
Agree. After N70 the new installations go to a particular folder.
No. I cannot find it. Interesting to know that I also installed the Java version of Intelligolf, and that installed without any problems and landed in the Applications folder. But with SlovoEd it does not show up.
Tom
Is an application that I don�t know. Is complete? Is compatible with the phone/OS? Maybe problem with screen resolution... Try install for the phone and / or for the card, and see if it appears.
