Changing color in a theme
3 replies · 3,598 views · Started 12 September 2006
Hello,
I am using a theme which i really like.
However, i face a problem.
Whenever i enter a URL in the "web", the letters are white in color. This makes it hard to see if i am typing the correct letters.
How can i change the color of the theme?
Thank you.
Unfortunately, you can't easily change the colors of a theme. You'd need to recreate a new theme.
And, unfortunately again, most themes have some color bugs such as the one you've encountered which means that even though there are quite a lot of themes available for the E61 already, only a handful of them are really usable and do not have bugs (the original Nokia theme, Aqua, MacGraphite_N71 and a few others). All that you can do, short of recreating a new theme yourself, is to contact the developer of the theme and let them know about the problem.
And here comes the third problem: it's often impossible to find the contact info of the creator of a particular theme since themes are often posted on various forums and web sites without the creator's name or contact info.
Sorry, i too would love to be able to use some of the really classy themes i've found but i can't because of these color bugs and i don't know where to send to bug reports to. :icon13:
i think the best way is create your self, me also feel like that, until now still using the default theme.
