[S60 2nd] online check of certificate alway fails
3 replies · 0 views · Started 12 September 2006
Hello,
i've an application with an uid of 0x2000000A for an S60 2nd3 application.
The application has been successfully signed with one of the test house
mentionned on symbiansigned.
Later, the application has been sold to a mobile network operator. I
upgraded some things inside and delivered it to the operator who signed it
itself.
Both version works fine when you install them.
However, when we activate 'check certificate online', the check fails with a
'revoked certificate' answer.
I've tracked the revoked certificates listing and found it is al:most empty
and none of the applications is listed.
How it comes than checking online certificate always fails ?
Hi Manisse
A Certificates revocation list (CRL) was implemented in v7.0s or 8, but was
never usedby licensees and was removed in v9. So if you've found this list
on the device then there is a good chance that whatever it contains is
garbage.
The actual check is done via OCSP, online, at the point of installation.
The obvious reason is that the certificate used to sign them has been
revoked. Does the installation fail for both SIS files?
Regards
H
"Manisse" <[email protected]> wrote in message
news:kQ%[email protected]...
> Hello,
> itself.
a
empty
The installation fail for both SIS files.
I don't think the certificate used has been revoked because it failed to be
checked online the same day it was made.
Also with our mobiles, even Adobe's PDF reader fails to be checked online.
( http://www.adobe.com/products/acrobat/acrreulaforsymbian.html )
Can someone check this product with the online certificate check activated ?
I feel it is maybe our operator doesn't allow to check online certificate.
"Hamish Willee" <[email protected]> a �crit dans le message de news:
[email][email protected][/email]a...
> Hi Manisse
> was
> garbage.
>[color=green]
> Regards
> H
>> Hello,
>> application.
>> it
>> itself.
>> with
> a
> empty
>[/color]
Hi Manisse
If the software installer can't check the server it should report this as an
error, not that the certificate is revoked.
I think you should email [email][email protected][/email] to see what the experts
say.
Regards
H
news:[email protected]...
be
> [email][email protected][/email]a...[color=green]
> > Hi Manisse
> > was
[/color]
list[color=green]
> > garbage.
> >[color=darkred]
> > Regards
> > H
> >> Hello,
> >> application.
> >> it
> >> itself.
> >> with
> > a
> > empty
> >[/color]
>[/color]
