Hi to all of you,
FileExplorer v1.02 is released,
Thanks to all of you who have send me encouragements and reports !!
what's new :
* the current path is displayed in the navigation pane,
* a confirmation dialog is display before deletting a file,
* the 'select button' of the navigation key gives the properties
of the current file
* new option in the settings : 'Light ON/OFF' which keep the
light of the display continuously on; if you toggle to another
application without closing FileExplorer, the light stays on
(great for the games)
* improved icons in the list
bugs fix:
* when a directory was empty, the right key crashed the system
(thanks to Michael Koo)
* in the previous version, the send command activated the
togglescreen insteand of 'send'
you can also download it via Handango at the following url : http://www.handango.com/PlatformProductDetail.jsp?siteId=1&jid=FB526DC1DEFC9X8BC541C3126481A5A2&productId=49269&optionId=1_4_2&productType=2&catalog=20&txtSearch=fileexplorer§ionId=0&platformId=4
