Issue Music Manager N73
1 replies · 5,569 views · Started 12 September 2006
I am trying to put some music (MP3 files on the PC) on my 2Gb mini SD card with the Nokia Music Manager. However, when I select music and try to convert/transfer these to my N73, the Music Manager application does not seem to do anything anymore.
I did not have any problems at all with the Nokia suite synchronising feature with Outlook. Also, getting pictures off the device works fine.
I can copy the MP3 files to the card with the file manager and they can also play, but then not from within the music player on the phone. So, therefore I prefer to use the Music Manager to store the music on my phone.
Am I doing something wrong?
hi on the phone you have to update music for it to load them just once then they will play, stick with mp3 if you convert to aac you can play different tracks for different callers, if you set an mp3 track as ring tone its for all calls
