which are for you the best bitrate framerate e video dimension to work with video mms to have the best of optimization and long time ?
best parameters for video mms
good question, I was about to ask it.
I have mine set at
bitrate 64 kbps
fps 10
video size 128x96
It still get horribly used up in a matter of seconds. Anyone wanna remove the file size limit? 😉
I have:
bitrate: variabile
framerate: 10
dimensioni: 160x120
video is about 20 seconds....
how do you change those settings? 😮
erm..open the prog..then options -> settings.
i guess it depends what language you have but it's the 4th option down on the options menu.
It's still limited to 100 kb???
😞 When will we have an app that we can fix our own kb limit?
Yes indeed when will the tchnology expand to break the 100kb barieer. This pesky number that eludes all our programming capabilites, this ellusive mythologoical 3 digit sequence of 1's and 0's which no one seems to conquer.
I foresee one day a man will come, yes a man not a woman, and he will show the people an application which will transend the shackles of this petty bondage, and allow us to leave the cradle of limitiations once and for all...................
just 😃
as the app is designed for sending MMS videos and the max file size for an MMS is 100kb, a service provider would have nothing to gain by having one coded without a file limit
what we need is someone to code an equivalent app, and not have it as a gimmick for MMS
Well i'm sure man did exceed that one-zero-zero limit. but he's just too smart to post it as an original app, without having to make mods and hacks. why don't they let us choose how many kb we want our movie? and also we can choose to make in unlimited! as much as our memory can take! That way version 3.12 owners can make sure their phone won't go kapoosh, and newer firmware owners can record as much as they please. and what about audio with it? not after it.
Piece of advice, that app is great, just add those two stuff, and it's perfect. cause the way it's made, you know, pressing the joystick to record, is the best thing they have ever made on the 7650 (after puzzle bobble 😃) so just those two stuff on an upgrade from who made this app.
please? PRETTY PLEASE? 😃 with cherry on top! 😃
