hi im not sure where to post this but i was wondering about pc suite when i plug my n80 in pc suite says there is no phone but the sync conection symbol says im conected to my n80 and i can still copy stuff like music and read my sms's is this normal it doesnt wory me but i would like to know, i think its the new version of it, it works ok on the older one
PC Suite
in the newest version of pc suite there is an exit option under "file" option in main screen.
select exit and reopen pc suite and see if that helps
mr plow,
try installing the latest version of the data suite from the nokia website, i had loads of problems using the version on the disc, but no probs at all from the website version
Try avoid a new install, before remove the old one. They said is possible, but donne a lot of problems. So, uninstall first, and then, install the new version after.
mr plow,
manta wrote:in the newest version of pc suite there is an exit option under "file" option in main screen.
yes it does thank you for your help and every one else aswell
