title says it all..6630, erased everything i could, songs pics, inbox outbox and such. tried to send myself a song through blue tooth and it says memory full ..
can anyone help me please
i just found this site and i probably could search for this, but these seemed faster...maybe
Search for mg2 directory on C: drive and delete it.
sorry, im a NOOB, i have no idea what that is or where to find it. and why do i need to delete it
Try a phone reset settings: *#7780#
aj7v wrote:sorry, im a NOOB, i have no idea what that is or where to find it. and why do i need to delete it
Use FExplorer and go to C:\System\Data and delete mg2 directory (or just the contents of it). This directory is used by Gallery and it's a kind of log from what I've seen. It's generated everytime when you enter Gallery.
Anyway, watch out what you are deleting. As nj7 said, do a backup first.
ok i got the fexplorer and erased the file i was told to. made sure all pictures songs and everything like that was erased. tried to send myself a song and memory still full. whats the deal?? the file isnt even large. I used to be able to put a few songs on my phone. the camera says i can take max amount of pictures and video is max length.
format ur memory card then try again !
Or format the whole phone. While at it, you could also try the latest phone software (firmware) for it: http://europe.nokia.com/softwareupdate
aj7v wrote:title says it all..6630, erased everything i could, songs pics, inbox outbox and such. tried to send myself a song through blue tooth and it says memory full ..can anyone help me please
Is it "Memeory full close some application" or "Memeory full delete some data" ?
Try set the Messaging to receive messages via MMC.
I have the exactly same problem, my phone keeps telling me "memory full please close some apps..." & it doesn't let me send SMS I've erased everything & switched to phone memory & nothing helped.
any ideas?
Above You have already some ideas. Try them!
"Memory full, close some apps" means that you have too many applications running inn the backgroud. Close some of them or use TaskSpy to kill them.
Zheyk wrote:I have the exactly same problem, my phone keeps telling me "memory full please close some apps..." & it doesn't let me send SMS I've erased everything & switched to phone memory & nothing helped.any ideas?
Me too - I cant restore factory settings as I dont know the pin (silly me - I canged it and cant remember what to!) - Whats the standard one?
Thanks in advance - this is driving me barmy!
The default lock code is 12345
