can anyone send VideoMMS clips without MMS?
6 replies · 3,059 views · Started 06 December 2002
this new app seems to work only with MMS.
does anyone know if it is possible to send clips using IR or email instead?
what about within SeleQ? does anyone know where the clips are saved?
nah, that doesnt seem to work. the clips are not there. :cry:
with the other video app (hentro i think its called!?) its saved there but not it seems with this new app.
Simon of BubbleGum is right. VideoMMS MP4s are stored in c:\nokia\videos
Hantros videos are stored in c:\videos
yep, soz guys your right. i couldnt find it at first! doh !
however, now tht i can see the file and im able to IR/email it using SelecQ the file is not viewable on my pc!
hope that makes sense!? can u help any further?
the hantro clips remain in mpeg format dont they?
update.
i renamed the file with a .mp4 ext and now when i IR it via SeleQ to my pc it works and i can view the clip. (i don know why before, but it wasnt working!)
after this I am able to view the clip using the platform4 player. im happy with that for the mo.
cheers for the help. appreciate it
