i have a n80 on the three network. it's only about a week old. it's the second one i have from them as i exchanged the first coz it kept restarting itself, however this one is the same. has anybody else got this problam and can any1 help me fix it. :con?
thanks
ps i have version v3.0618.02 23-05-2006 rm-92 nokia n80(45.02) if this helps
I havent had this problem much, maybe two or three times since i got the phone in March.
As with most problems, the latest firmware upgrade has solved prety much all my problems..
To check which firrmware you have press *#0000#
The latest will show at the top V 4.????
Well try find a Nokia service centre that has the V 4. firmware or upgrade yourself using the guide on this forum.
im on 3 too, wanted the latest firmware, went to ma local nokia centre, but only to find out they cudnt do it yet, because some 'product codes' for three aint been released yet, so they cudnt do it... 😞
Do it yourself, its not difficult, just takes a few downloads and an hour or two to figure out the applications.
The only reason your network wont do it is because they havent got their version of the firmware, which would include their adds and logos on your phone. Damn cowboys..😡
