hi there,
anyone here has this problem?
my N80, whenever i set a new/old theme or wallpaper, and after on & off the phone, it will goes back to default.. no new theme no wall paper...
any ways to solve this? thanks!~
hi there,
Seems a bit weird. Never seen such behaviour myself.
Only with one theme or does it happen with other themes, too? Try several.
Built-in themes too, or only with what you've installed yourself? Try both kinds.
Installed in phone memory or the memory card? Try with both.
Operator-branded/-locked phone or not?
Phone firmware version?
N/A wrote:Seems a bit weird. Never seen such behaviour myself.Only with one theme or does it happen with other themes, too? Try several.
with all of my theme, even nokia default theme, i set my wall paper, but after off/on, my wallpaper is not there..
i put other theme not by nokia, also like tat, when on, it will go back to nokia theme..
v 3.0617.06
RM-92
Something happens to me with N91. Is a firmware problem. Do the firmware upgrade as is solved (or should be😉 ).
nj7 wrote:Something happens to me with N91. Is a firmware problem. Do the firmware upgrade as is solved (or should be😉 ).
oh.. but how come some of my friends with the same firmware does not have such problems?
how long they need to upgrade my firmware? hope its doesnt take days.. 🙄
rehtsemis wrote:oh.. but how come some of my friends with the same firmware does not have such problems?how long they need to upgrade my firmware? hope its doesnt take days.. 🙄
I don�t know explain why... but this thing happens to me with N91. With foruns information, seems that a firmware upgrade resolve the things. I never try that, because I get rid myself of N91, because that is not the only problem, before do the upgrade.
nj7 wrote:I don�t know explain why... but this thing happens to me with N91. With foruns information, seems that a firmware upgrade resolve the things. I never try that, because I get rid myself of N91, because that is not the only problem, before do the upgrade.
oh ok. thanks!~
Actually, I had this happen earlier today.
it coincided with switching SIMs too, most odd.
Mine was using a 3rd-party anime theme and after it happened the theme had disappeared from the list available on my phone. Trying to reinstall it fails too. 😞
Tra
Pig
jasong wrote:Actually, I had this happen earlier today.it coincided with switching SIMs too, most odd.
Mine was using a 3rd-party anime theme and after it happened the theme had disappeared from the list available on my phone. Trying to reinstall it fails too. 😞Tra
Pig
oh.. my n80 nv like tat.. urs wat phone? heard that n80 always have problem, esp the sd card.. might need format.. but not too sure whether its the sd card or the firmware.. sad.. its less than 2 weeks..:frown:
rehtsemis wrote:oh.. my n80 nv like tat.. urs wat phone? heard that n80 always have problem, esp the sd card.. might need format.. but not too sure whether its the sd card or the firmware.. sad.. its less than 2 weeks..:frown:
nj7 wrote:But your version of software are a problems. Do the firmware upgrade to 4.xx, because seems to improve the work with the phone.
oh ok. do u know how to format n80 phone.. not memory card...
rehtsemis wrote:oh ok. do u know how to format n80 phone.. not memory card...
i have this problem after i upgraded my FW to v4 ,even my font restore to origin after i changed it ,i tried to reflash it but nothing happened
i think its because of some app. we both installed on the memory card
did you install your theme on memory card or on phone memory ?
With N91, it happens even with themes from phone (from original software), and return to defaut theme.
lovher wrote:i think its because of some app. we both installed on the memory card
i install both the setups and installation in the memory card...
lovher wrote:i have this problem after i upgraded my FW to v4 ,even my font restore to origin after i changed it ,i tried to reflash it but nothing happened
so does it got to do with the firmware? cos i dunwan let my phone stay at Nokia too long, then i got no hp to use..
nj7 wrote:Soft format: *#7370#; Hard format: Green + * + 3 and power on.
But that don�t avoid the need of software upgrade.
Last version for N80: 4.0623.0.41.
gosh.. dunno y .. my lock code is always like tat..
the orginal code is 12345 right? after enter, i wan change it, then they prompt mi wrong code.. den i cant format liazo..
anyway i dun understand the hard format way.. can explain..
cos i wan try to c if works.. cos i dunwan bring down to uprade it, it might takes few days to do it, cant do it w/o a phone.. thats y.. haiz..
i have upgrade the version, no problem le.. but after i restore my things back using pc suite, the problem came back.. but i format my hp later, everything went back to normal.. i think sth got to do with the pc suite though.. perhaps..
rehtsemis wrote:i have upgrade the version, no problem le.. but after i restore my things back using pc suite, the problem came back.. but i format my hp later, everything went back to normal.. i think sth got to do with the pc suite though.. perhaps..
After restore... is not PCSuite, is some installed program. Try find wich one.
i got this problem before too, because of me set a passwrd for the memory card.
if u do so, try to remove the password n see.
