N91: Problems after 2.00 update
3 replies · 4,254 views · Started 16 September 2006
Hi, just wondering if anyone is having problems opening applications you could open before updating to version 2.00 on your N91.
There are several games (Nokia Snakes!, etc.) and 3rd party applications (Best Taskman, etc.) which worked before the update, but which are not functioning after a fresh reinstall after the update (I know that I haven't made any mistakes, for example, leaving the hard drive files intact after the update, so that's not it, I completely formatted then reinstalled everything on the hard drive, that's when I found out that I couldn't use these programs.)
Also, should we start a wish list for the next update? I think the speaker phone is too low in volume (music playback isn't, so it's not a limitation of the hardware...)
Would like to see if anyone else has experienced this after the update, thanks!
I know it's nothing I've done. Check some of the other N91 update threads, same software not working for other people after update as well!
yes..... it is a major problem for me as well... thought all the themes are working fine now..... the best taskman/best fscaller / best....... stuff do not work anylonger...... also yes the snakes! which were all working finr b4.... i guess it's like some old programs failing to work after upgrading to winXP sp2 from standard... lol... but i guess the developers will correct this problem in there next realease most probably.......
that's wat i am hoping... .coz it's hard without some good apps like fscaller... but most of the other apps are all fine......
..... and i guess it fixed quite a number of buggs on ma phone... like the HDD disconnecting most of the time... and applications not closing down properly
