I often associated text with my Todo notes in addition to the actual title. When I sync, the todo's all show up with titles, dates, etc. but the actual text is either not sync'd or doesn't show up. Has anyone else noticed this and/or have a proper setup?
Todo Note Text
jjprusk wrote:I often associated text with my Todo notes in addition to the actual title. When I sync, the todo's all show up with titles, dates, etc. but the actual text is either not sync'd or doesn't show up. Has anyone else noticed this and/or have a proper setup?
It's a limitation of S60's very weak to-do app. Complain to Nokia - no, really. Use their Support form and couch your message as an omission/bug - I'm told the development teams do get passed bug reports.
Steve
Glad to see its not just me 😉 Do you know if the actual body of the todo is transferred (ie, is resident on the phone) and its simply the app that fails to show the information? If so, then I assume a more advanced 3rd party app would be able to display this information.
No idea. Hope so, though 8-)
Steve
jjprusk wrote:Glad to see its not just me 😉 Do you know if the actual body of the todo is transferred (ie, is resident on the phone) and its simply the app that fails to show the information? If so, then I assume a more advanced 3rd party app would be able to display this information.
It is the built-in application. If you look at the PC Sync log you can see the text being transfered. Also, I have a beta copy of Papyrus and can view the text with it.
