i have nokia 6600,
i send from pc to nokia a mp3 file (send with bluetooth), how can i remove mp3 from messages to other derictory?
when i get in the option of the message i haven't save option (;ike i read in the nokia guide).
thanks
i have nokia 6600,
thanks
Open the message from Inbox. In the player, save it. Exit the player. Delete the message.
i open mp3's not with nokia player, it doesn't open mp3s,
i use ultraMP3 and there isn't save option.
Simple: FExplorer, go to inbox option and select what you want to move from it. Paste the file anywhere you want and delete the message.
If your mp3 sound cannot save in your nk 6600, try to install FILE MAN..... so try to save your mp3 from file man.............. Good luck......
maximz wrote:i have nokia 6600,
when i get in the option of the message i haven't save option (;ike i read in the nokia guide).thanks
I am using an application called forward, which can copy files from inbox to folders on mem card or phone.
http://www.compsoc.man.ac.uk/~ashley/
