Installing Applications?
8 replies · 3,087 views · Started 17 September 2006
Hey, i couldn't figure out how to install apps from memory card data transfer, and my laptop isn't installed with a bluetooth device, so i tried Nokia PC Suite, and when i try to install the apps, after it finishes, they just say Unable To Install.
I've been trying eMSN and mini Opera.
Would like some advice if possible.
nj7 wrote:Copy the files to the card, ten install from there.
I have tried that, but i can't browse the memory card files from the phone, and therefore cant execute the app manager to install it.
nj7 wrote:Use a card reader instead.
I have, the applications are inside the memory card, but once i read the memory card using the phone and try to install the app, 3/4 the way through it comes with an error UNABLE TO INSTALL!
There be a software conflit over there. Or You made de dtection, or the way, is format the card and install all again (not the one that made the problem:frown: ).
I have both on my N73, without any problem. For eMSN, are alternatives, like QuickIM or Hier, both free.
