Well, sorry to bother you folks. Turns out, that I just needed to take out and reinsert the memory card for everything to work again.
I have a rather stupid problem.
I installed all those nice applications on the bundled memory card (Worldmate, etc.).
I changed the name of the card and the applications won't start now. I am guessing that I need to change the name of the card back.
So, can anyone help me out and post the name of the memory card that comes bundled with your Nokia E-61.
(or maybe point me to installer SIS files for the bundled applications? Nokia has all but the Worldmate application online)
BernieF wrote:Well, sorry to bother you folks. Turns out, that I just needed to take out and reinsert the memory card for everything to work again.
Would you have set up a password for your memory card or activated the remote lock feature by any chance? If you have then chances are that the problem is going to come back every so often forcing you to remove and re-insert the memory card (actually, you don't need to physically remove the card, just choose "remove memory card" then press ok when it says that you can remove the card and things start working again). The only solution to this problem seems to be to remove the password
