Alright, I'm using E 61, symbian 60 3rd edition.
Now here comes my problem.
I wanna use my one of the function, that is to get into a browser, a betting website that calls gamebookers. And everything works fine...til the last step it fails. It browses like I'm in a pc like where I'm typing now and I click and click to select my betting slip. Until the end, when I choose my selections, it will calculate automatically about the possible payout and how many selections I made, all calculated, but with my phone, it just won't happen, so I can't bet. Something is missing I believe. How can I help this? Does anyone know what is the problem that lies behind?
Nokia E 61
Same thing happens with other sites and other N series phones. Miss support for some plugins and codecs. But is like that!
Now, I found that gamebookers have an wap site which is wap.gamebookers.com and whenever I enter the address then it would say, "unsupported content type". What's the problem? The website told me to check whether I have a wap enabled browser which is yes and check my connection settings. So what's wrong with my settings? Anyone know?
You may be able to access WAP content by using the E61's older "Services" browser instead of the normal browser. "Services" was designed for older phones and works with WAP, but it can't cope with normal websites which is why it was replaced with the new browser.
You can find "Services" by pressing the Menu key, then going to Media, then Services.
