I've been using the supplied 64mb card in my E61 for the past couple of weeks and eventually got round to buying a Kingston 1gb card.
I've backed up card and phone using PC Suite.
Is it just a case of putting the new card in and restoring to the new card, or will I have to re-install and applications that I had installed on the 64mb card?
clive
c53204 wrote:I've backed up card and phone using PC Suite. Is it just a case of putting the new card in and restoring to the new card, or will I have to re-install and applications that I had installed on the 64mb card?
I don't know how PC Suite does it, but I just manually copied the contents of the supplied card to my new Sandisk 2Gb using a cardreader. Works fine - no need to reinstall the software
