Hi to all the modders, I have got Nokia 6680 which is locked to 3 Ita. And i need to flash this phone to unlock the SIM and other restrictions.
Currently it has sw;
V 5.04.07
15-02-06
RM 36
and i have successfully installed following sw in my mechine;
Phoenix Service Software 2006.20.9.148
Diego 3.06
and i have got miro_rofx_3[1].0617.0.6.V08 and miro_3.0617.0.6_prd_western_C00_cc.fpsx. I have installed the cable drivers as well. so when i try to flash this, it started giveing me following errors;
1) "In order to flash the PPM file succesfully, the version of the Flash update package installed in the prommer must be at least 06.02.002. Unable to determine the flash update package version in the prommer. do you want to continue YES?NO"
so when i say yes it goes to the Flashing mode and give me the following error.
"Failed to save all user settings are skipped.
PSN or Product Code is empty.
Or settings file not found for this product.
Do you want to continue?
HRESULT 0x80004005 (-2147467259)
This means:
Unspecified error
Or settings file not found for this product.;Flash=0x80004005"
if i say retry.. it gives me the following message;
"Changing phone's operation mode failed.
Do you want to retry?
HRESULT 0x80043005 (-2147209211)
CMtcFN::SetCurrentMode, transition not allowed;MTCFN=0x80043005"
so i canceled the flashing. and set the phone mode to Local and tried. so here it says;
"Flashing failed.
Error occured during the flashing procedure.
Phone Adl mode did not start. Try again.
HRESULT 0x84012260 (-2080300448)
Flash: Adl Server did not return Rootkey Hash correctly. Phone HW may be too old "
and here is the log;
Reading data from phone
Reading phone information
Reading product type
Reading product code
Reading PSN
Get flash file names
Reading IMEI
Reading HW version
Reading flash settings from file(s)
Starting AdlLoaders, wait 15 seconds...
Starting flash...
Starting USB flashing.
Cmt->Trying to verify communication 1 of 2
Cmt->Trying to verify communication 2 of 2
Cmt->Failed to verify communication.
Cmt->AdlServer: Phone info requested succesfully
Server did not return Rootkey Hash codes. Operation Aborted.
Flashing failed.
Flashing failed.
so why i'm getting this error? is there a way of fixing this? is there any other flashing software available? i really apreciate if you people advice me on the above issues and give me a solution. thanks a bunch.
Bye.
Gihan
