Dear all,
I tried to use E61 to access our company email. After completing the setup, I can only read the mail. Every time when I try to send the email, it will show "Unable to send message ". Our company email system uses SSL encruption, and I am sure the port setting is correct. However, I try to use "ProfiMail". Everuthing is okay. But the software can not show the Chinese words correctly. Can anyone help me out? Is anything I need to care or it is a bug of Nokia?
Thank you in advance. Have a nice day.
It's a weird bug with SMTP/SSL in version 1 of the FW, it seems to be fixed in version 2.
Also check http://www.allaboutsymbian.com/forum//forum/thread/48344/
Thanks for your help.
My sofeware version is 2.0618.06.05 14.07.06 RM-89
Is it the version 1 or version 2?
Where can I get the latest version?
Thank you.
polinchi wrote:Thanks for your help.
Thank you.
You've got the latest version there.
Dear all,
I still can not mail now...:frown: :frown:
I find a problem about the port setting.
When I choose the user define and set the port of outgoing to 465.
It will change back to default when I exit the setting screen.
Is 465 the default value?
Please..
I do not want to use Profmail..It is not good looking and can not read Chinese words...
