Recommended windshield car mount for N80?
1 replies · 1,974 views · Started 22 September 2006
Hello!
Tomtom v6 sounds great for the N80 and I'm looking forward to purchasing it!
However, I now need a windshield mount for the phone and was wondering if there any decent ones available? Ideally it needs to be a powered mount or one that supplies the necessary lighter socket cable...
Cheers,
Paul.
w01f wrote:Hello!
Cheers,
Paul.
Halfords do an excellent one at around �14.99 in a choice of 2 colours (black or silver).
It's sucker mounted on windscreen (no glue or screws required) and easy to remove without leaving marks, has a telescopic flexible arm and adjustable width holder which grips the mobile firmly.
Also, this holder fits the N80 perfectly and there's even a gap where the N80's camera button is so the holder does not accidentally press the button.
Dez
