Hi, has anybody bought tomtom 6 mobile/pda of ebay yet? and tested it on the N80 ? This seems to be a confusing subject as it works with the E61 , and on the mobilefun website it also states clearly will work on the N80 , so would be good if anybody has actually tested it, maybe i should buy and test it in my N80, Not a bad price either for software only, sorry if posted this in wrong section, just wanted to see if anybody has got it working ok and i also suppose you would have to upgrade to the latest firmware to, hope to get your comments etc,
Brian
it works on n80 theres no where to buy it yet but some ppl have downloaded it and are using that
Seems that work well on all S60v3 phones.
yeah i have it wroking on my n80. runs soothly and i havent encountered any of these bluetooth dropout that people have been reporting
onis_uk wrote:yeah i have it wroking on my n80. runs soothly and i havent encountered any of these bluetooth dropout that people have been reporting
I think it depends on the firmware version, I had major problems with BT connections until I flash it to v4. 😮
Jak wrote:I think it depends on the firmware version, I had major problems with BT connections until I flash it to v4. 😮
Before version 4, all Bluetooth related things doesn�t work very stable.
