Unable to sync calendar and task list details
1 replies · 2,215 views · Started 23 September 2006
I am using Nokia N70, Nokia PC suite 6.80.22 with Outlook 2003.
I am not able to sync the details that I have key in using my outlook 2003 under calendar and task.
Is it that the phone does not support such feature? Please advise.
Calendar yes, task, I�m not sure. But the problem should be the PCSuite installation. Remove all, clean the registry with a regclean program, pcsuite entries related, reboot PC, and install again the last version of PCSuite. Should work.
