Alright, so tops of it is i just purchased a Nokia N80, overall i am happy with it, as i have upgraded from my Nokia 6600. But i got a couple of problems :[
Problem number 1 -
Games, Game i downloaded evan from this website, and any other S60 website i get them turning up in a lil box on the screen, so they will fill up 1/4 of the screen and the rest will be a blank white screen. So it makes it near impossible to play any games at all. The only games that work are the games that come with it, I downloaded Zelda for instance and that is in a tiny box in the right hand corner.
So any1 have the same problem or can suggest me on what games i can actually download?
Problem numeral 2 -
From reading the Foums i have read that you cant use Tomtom Mobile 5 on this fone? Am i correct? Because some people claim they can and some people claim they cant :/
Thanks for reading and i hope you can help!!
Ralphy 😊
1. Are Java games, correct? That kind of games need to be for the screen resolution of N80, and not for screen resolution of 6600. So these files are not for N80 and You need new ones.
Free software, see here: http://stevelitchfield.com/nonagss60.htm (but only for S60v3).
2. TT5 doesn�t work on N80 neither any S60v3 phone. Only TT6. Is the same for other software, only for S60v3.
Cheers for trying dude, but
Ye i made sure i downloaded new N80 games, But once again i tried the link you have given me "http://3lib.ukonline.co.uk/nonagss60.htm" but unfortunatly None of these work and i mean None :/ are you sure thats the right link for S60 V3 software and games?
And if not is there anywhere else i can try because i want to see if its my fone or i am just using the wrong games :[
Please help lol
Ralphy
Some of them are for S60v3, not all... take from here the Tetris game for S60v3 with screen resolution for N80: http://www.s60tips.com/
Well i just go myself Tomtom 6 😮
Now it doesnt work ;[
Maybe i need to update my firmware? if i type in *#0000#
It says ~
V 3.0617.0.6
03-05-2006
RM-92
Nokia N80 (33.01)
What software and files do i need to do this?
And what is the success rate? Coz i aint up for breaking my new phone :[
Thanks Guys!
Ralph
these work from this site: http://www.series60v3.com
