Hi there,
although i've read all the topics of S60 series, i haven't noticed such problem.
My new E60 can connect to all wi-fi including my neighbours wi-fi's but i cannot connect to my home wi fi.
i choose "select wi fi" than my wi fi appears with very strong signal (since it s near me) than i choos it it says connecnting but nothing but a blank page..
i tried the same with opera .. nothing changed.
then i go near the window, search for wlan again. my wlan and my neigbour's appears, i choose my neigbour's it works! (although the signal is weak)
as for my wlan, i dont use WEP nore MAC filtering..
it s totally open..
my wireless adsl modem is US Robotics.. (maybe it useful??)
i can't even connect to internet via ippassthrough..
anyone with any ideas????
i really need your help..
Have you tried disabling power saving in the WLAN Advanced Settings on the E61?
E61DRC wrote:Have you tried disabling power saving in the WLAN Advanced Settings on the E61?
yes i tried, unfortunately it didn't work 😞
Dont you have a mac address filter in the router or some protection that dont let you connect?
pantoche wrote:Dont you have a mac address filter in the router or some protection that dont let you connect?
i don't have anything.. it's totally open and public..
Wirelessly posted (Mozilla/5.0 (SymbianOS/9.1; U; en-us) AppleWebKit/413 (KHTML, like Gecko) Safari/413 es60)
What make is your router? I'm using a safecom and have no problems
guys i reset my modem. (robotics 9016) and did all the settings again.. it's fixed.
I have an E61. My problem is slightly different (probably not technically) but I am able to connect easily to my home network (unsecured) but not to any other public unsecured networks. 'have tried at hotels & airports. Its very frustrating and the previous solution of resetting the routers is not available(!!).
Any help / suggestions would be appreciated.
Regards
try to change the setting of "power saving mode" in wlan options.
icicibank wrote:I have an E61. My problem is slightly different (probably not technically) but I am able to connect easily to my home network (unsecured) but not to any other public unsecured networks. 'have tried at hotels & airports. Its very frustrating and the previous solution of resetting the routers is not available(!!).
Regards
I have got that problem, too.
I can't seem to connect to WLAN/WiFi Hotspots on the go.
Instead, I always have to actually create an access point setting (like you would do with your home's wireless network). This way, it always works... but of course, that's a hassle to always having to create a setting for using some public hotspot
has anyone tried to create an adhoc connection, and use that to browse?
I have got it working but it resets as soon as i exit the browser.
anyone else had a similar experience?
