Video quality
8 replies · 2,232 views · Started 24 September 2006
Hi ,
the video in 7610 is .3gp file.When transferred to PC it can be viewed only in a small frame.How I can get the video in full screen?
K I N D L Y G I V E A S O L U T I O N.
PLISTAPUSA wrote:Hi ,
Try using RealOne Player or Helix(From Real Website) it helps sometimes..😊
ratza wrote:Do you want to see the clip fullscreen on PC or on the phone?
Good point!
lol... cool point here ya....
to view 3gp, for PC ya can use Quicktime and RealPlayer.
yes its small screen...cvoz of screen size are 220x178.
normal sizing are 320x240. (normal vcdsizing)
quality are 640x480 and more.
so .. now ya understand.....but dont worry ya...
video taken (7610) ya can covert it to WME,AVI,REAL with
XilisoftVideoConverter or #1 Video Converter or AVS Video Converter or etc.
and encode it for bigger sizing screen ok.
p/s : from there ya can make vcd or supervcd .....
Where did you see this resolution, man? You meant 208x176, but the recording is 176x144 or 128x96.
ratza wrote:Where did you see this resolution, man? You meant 208x176, but the recording is 176x144 or 128x96.
bro.. sizing are setting by ya phone
... 208 x 176 are (mostly full screen for phone)
remember to set high video recording ya...
so ya can convert it for better QULAITY....
regards.
Hey i suggest that u convert the video to a format that can be view by windows media player...
