Hello,
On behalf of exoSyphen Studios, I would like to introduce Go-Widgets!
Go-Widgets delivers the information you are interested in, with the elegance of a few keypresses, perfectly formated and served for the device you are using. Say good-bye to using several pieces of software or visiting websites to gather the information you need.
Wether you use your computer, a cellphone, pda or any other device that is capable of an internet connection, you get the same content seamlessly.
Go-Widgets brings the services you use everyday, to a device of your choice, through small applications, called widgets.
Create your own widgets to generate revenue, promote your service or website, with our easy to use SDK. Our staff will offer your complete assistance in the development and deployment of your widgets.
