applets java on P990i ???
4 replies · 7,939 views · Started 25 September 2006
Hello
I have a P910i with opera 6.32.
Applets java works perfectly in the browser.
With the P990i with opera 8.60,
applets java don't work at all.
A message saying : java is not available.
Well ? Does the P990i supports applets?
Why P910i supports applets and not P990i ?
Thanks to answer me !
What such a response !!!
So, explain me why applets don't load in P990 where P910i works perfectly ?
Is a firmware bug ? Thanks to answer me more than a simple 'yes'.
No clue. Don't have a P990.
Sony Ericsson web site ( http://developer.sonyericsson.com/site/global/products/phonegallery/p990/p_p990.jsp ) say that these Java technologies are supported on the P990:
Both CDC and CLDC environments supported:
JTWI 1.0 (JSR-185) consisting of Connected Limited Device Configuration (CLDC) 1.1 HI (JSR-139), MIDP 2.0 (JSR-118), WMA 1.1 (JSR-120).
- PDA Optional Packages (JSR-75)
- Bluetooth™ (JSR-82)
- Wireless Messaging API 2.0 (JSR-205)
- Web Services (JSR-172)
- Mobile Media API (JSR-135)
- Mobile 3D Graphics (JSR-184) with hardware acceleration
- Nokia UI API 1.1
Connected Device Configuration (CDC) 1.0 (JSR-36)
- Foundation Profile 1.0 (JSR-46)
- Personal Profile 1.0 (JSR-62)
However, the browser in the P990 might not support Java applets, even if the version in the previous model might have.
Have you asked Sony Ericsson's customer support?
http://www.sonyericsson.com/spg.jsp?cc=gb&lc=en&ver=4000&template=ph1_2&zone=ph
dreamed wrote:What such a response !!!
You phrased your question so beautifully that I couldn't resist, but to provide such an elaborate response as I did. Do we owe you an "explanation" on that too?
