Sat Nav on P990i
8 replies · 10,258 views · Started 25 September 2006
Hi
Is there anyone using their P990i as a Sat Nav device?
If so what setup do you have?
Thanks.
Que? Do you mean use as a GPS system? No big setup, buy and install Wayfinder and get yourself a bluetooth GPS receiver and that's it.
Thanks for that.
I had a think last night and was wondering if it was such a good idea to use the P990i as my sat nav as I also want to use it via bluetooth to talk on.
I guess it may be able to handle sat nav and a phone conversation at the same time, but I thought it may be a bit iffy.
So I looked on eBay last night and P910i go for �100 to �160. By the time you add on a GPS receiver at say �40 and the cost of the software it didn't seem worthwhile, when you get all in one Sat Nav for under �200.
Anyway I chatting about Sat Nav's @ coffee break this morning and a colleague said I could have his TomTom 700 for �200. He bought in Feb but doesn't it. It's in pristine condition and he has all the stuff that came in the box and his Halfords receipt.
When I get the manual tomorrow and all the other bits I'll see if I can get ny P990i to work via Bluetooth for calls.
Thanks anyway.
I am a little confused, Wayfinder sat nav is not compatable with the P990 at present. Wayfinder customer support have advised that software 6 will be updated on the 16th October, only then will the P990 be supported.
Any other sat nav software compatable with P990 at present?
Is the web site gneedg.com the right address as i've tried it quite a few times but keep getting the unable to access page at this time-try again later message.
bigrob wrote:Thanks for that.
Thanks anyway.
Hi everyone.
I've used it (just to see if it worked) with TomTom6 + BTG7000 ( that is a GPS) (via blutooth), and at the same time it was linked to my BMW's bluetooth interface for thelephone call. In fact I was able to see al the list of tel contacts on the cockpit, but I wasn't able to hear the voice of TT6 neither from the phone nor from the car's loudspeakers. I do not remeber if i received or made a call during that trip, but apparently all was ok on the P990i's display.
mine:
Tel CXC162037 R7A001
Blu CXC162058 R4F01
Org CXC162036 R3B01
cda CXC162008/65 R3A01
I hope this can be useful for you.
Al116
A
You would make your life alot easier if you just get a handheld navigation system,or wait for phones with this system built in ( N95)
