Is it just me or are the pop-port connections unstable
5 replies · 2,442 views · Started 25 September 2006
Do you guys get loose connections when using either the usb pop-port connector or the pop-port stereo headset?
Everytime I connect my phone to a usb adapter, any slightest movement to the connector can disconnect my phone from the pc.
The same goes with my pop-port stereo headset, I have to make sure the connection is tight or else headset will disconnect and the sound will start to come out from my phone's speakers. It's getting pretty annoying..sigh
yer i have noticed this from time to time , try cleanin the pines and the slots that helps, really i wud luve to see a proper dock for this fone and one for car like the port was designed for, and not have to put up with some generic fone holder
cah1982 wrote:yer i have noticed this from time to time , try cleanin the pines and the slots that helps, really i wud luve to see a proper dock for this fone and one for car like the port was designed for, and not have to put up with some generic fone holder
Yea... time to time that happens! Is not the most well connection. It should be a mini USB - connection / charger😎
nj7 wrote:Yea... time to time that happens! Is not the most well connection. It should be a mini USB - connection / charger😎
-like they are moving to on the n95! -or so rumer would have it!
sm1thson wrote:-like they are moving to on the n95! -or so rumer would have it!
We go see today if is true🙄
