Header retrieval disabled
0 replies · 2,002 views · Started 25 September 2006
I have a couple of questions about email on the E70, and I have not been able to find answers to these on the site.
1. If I set Auto Retrieval to work "Only in home net." it never works even when I am in my home network. Any ideas?
2. After various amounts of time using automatic header retrieval, I will get this error message:
[INDENT]Unable to connect.
Check conn. settings of <account name>. Header retrieval disabled.[/INDENT]
Sometimes this happens several times per day, and I have to go into the settings for each email account and reenable the feature. Can this be stopped? If it fails to connect, it should just try again later.
3. The email application does not seem to support the concept of "leave email on server." Is this hidden somewhere?
4. If I use the email application with Gmail, it complains every time that the SSL certificate cannot be trusted. But there is no obvious way to accept the certificate permanently. How can I accept the certificate permanently?
Thanks for any help you can offer,
Gus
