Hi There,
Does anyone know whether it's possible to move applications from phone memory to the memory stick? So more memory can be freed up for the phone?
Thanks in advance for any help.
Hi There,
Properly only, if you uninstall from phone memory and reinstall on the memory card, instead.
When you uninstall from the phone memory, would the application be saved somewhere so I can reinstall it onto the memory stick?
