i now using a 1gb kingston mini sd card on my n80(V3.0614.0.3).
the phone lags alots or even hang when i enter my gallery..sometimes when i have more files stored in the card, it lags too when i take photo even thought the photo is save in phone memory..
anyone has this problem?? pls help...which brand and capacity of memory u guys recommend? thanks.. ; )
First of all, if there is a nokia centre near you, upgrade your phone firmware to V4. Otherwise, just wait for the Nokia Software Updater to add N80 to the list.
http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdate
I heard people having problems with Kingston & Sandisk memory cards on earlier version of n80(V3.0614). I would recommend either Transcend or Adata.
I have a 2GB Transcend on my n80(V4) and there is no lag at all.
jin1212 wrote:First of all, if there is a nokia centre near you, upgrade your phone firmware to V4. Otherwise, just wait for the Nokia Software Updater to add N80 to the list.
http://www.nokia.co.uk/nokia/0,1522,,00.html?orig=/softwareupdateI heard people having problems with Kingston & Sandisk memory cards on earlier version of n80(V3.0614). I would recommend either Transcend or Adata.
my location is in singapore..the latest version here is only v3.0617.. is there still have bugs problem with this version? if 2gb functioning well with v3?
Agree with "jin1212". Firmware upgrade and avoid kingston cards for phones.
v3.0617 should be sufficient to fix your problem. I had v3.0617 for around 2 months and there were no problems with my 2GB transcend memory card. If you still get a lag after the upgrade, try getting another brand of memory card.
nj7 wrote:Agree with "jin1212". Firmware upgrade and avoid kingston cards for phones.
kingston cards are not very reliable..think i should change to 2gb of other brand..should work well with v3.017..
