Hi All
New to site.
Just got my nice new N80 and using Nokia Media studio to convert files so can watch them on the train.
My problem is simple is there another program to real player that will give me the sliding bar to choose which part of film I can start from, as real player just starts from the start of the film and must of watch this part 4 times now.
Many thanks
CJ
Well, you can use the up key or the down key to go to any part of the movie (based on time mm:ss) in real player....
Thanks will try that, I couldn't find the controls, bet you it was in the manual I didn't look at.
vin_eme wrote:Well, you can use the up key or the down key to go to any part of the movie (based on time mm:ss) in real player....
:con? I thought the up key/down key controlled the volume? I can't jump to a certain time in real player either :con?
Real Player is enouth. Use SUPER to make compatible movies.
The fast forward/rewind function does not work if you open the file up in the gallery.If you open up your video file in file manager the up and down thumb button fast forwards or rewinds the file. Left to right still adjusts the volume. Once you have reached your desired point, stop the video, press options and select continue in full screen. Pressing the up & down button will take you out of full screen and fast forward or rewind the file.
